holding tank replacement?
Mike Elmore
all, has anyone replaced their holding tank? I imagine most Catalina's have oddly shaped holding tanks (read not nearly square) like my C28 as they try to get them as big as possible out of the way. I want to replace my black tank with opaque poly(won't even try to spell it). I have no inspection port and would rather just be able to sneak a look to see if it's getting full rather than holing a port into it and adding a tank monitor. The size is just so wierd. it's under the port seat and is 11" high on the cabin side and 4" high on the hull side tapered between the 2 heights to fit into the hole. Any idea where I can get a new one sized correctly? Mike Elmore Windward Hull-C28 Hull #7
L
LaDonna Bubak - Planet Catalina
Check with Peggie
Hey Mike! Go on back to the home page & click on The Head Mistress forum. Peggie is all-knowing about head systems AND she even has a line of weird shaped tanks (I have a copy of her catalog and there is a veritable multitude of funky tanks!). Ask this same question over there & she'll point you in the right direction. LaDonna
John Mavrovich
Tank Monitor
Something to consider. It's easy to do. TankWatch I cost $38.20 in the Defender Industries catalog. The red warning light can be mounted at the nav station or near the head. Mine works great.
