All holding tanks should be rinsed out 2-3 x year
After pumping out, put several gallons of water--enough to cover the bottom to a depth of 4-6"--into the tank via the deck pumpout fitting...'cuz that sends the water into the tank at the bottom to stir up the sludge. Pump that out...repeat...repeat...till you're only pumping out clean water. If you have a macerator to dump the tank, do it one more time while running the macerator to clean the sludge out of it and the line to the thru-hull.This should be done at least 2-3x year...and especially before winterizing. I suggest you check out the link below for this and more tank--and tank vent--maintenance information.
