Holding tank cleanout.
Dec 19, 2006
5,832
Hunter 36 Punta Gorda
Bigger
Even if you get the bigger boat you will need to empty any way,if 6 adults what I do if don't want to use my holding tank liquid only I use jugs 1 or 2 gallon jug and just empty in home tiolet.
I have seen portable electric pump out for people in your situation and it pumps
in and out on wheels.
Shop vac sounds like it could be messy to empty:eek:
Nick
Sep 17, 2012
112
Morgan 383 Fairhaven, NY
You have to go porta-potti. Cheap simple and effective. Used one for years on a variety of boat, no leaks either.
Remember if you put one of those blue packets that deodorize the brew, don't pour it down the toilet if you're on a house septic system. It may kill all the microbes that keep the septic functioning. Best in a city sewer.
No deoderizer and its safe in the septic.
Oct 15, 2009
220
catalina 320 Perry Lake
You and guests can take an occasional "swim" to cool off and refresh
Oct 26, 2008
6,370
Catalina 320 Barnegat, NJ
I applaud your sense of propriety! Or ... you must have some pretty intense enforcement! BTW, how's the regulation of agricultural runoff measure up in that area?
Jun 2, 2004
3,604
How Far From Dock to Septic Tank?
A pump, a hose and some pvc pipe and your all set.
If you allow your neighbors to use it you may even be able to get a grant to pay for it.
Gunni
Mar 16, 2010
5,937
Whale makes a couple of different manual waste diaphragm pumps that could be plumbed into your system with a valve and would allow you to pump out your holding tank.
Aug 15, 2012
301
Precision 21 Newburyport MA
How about taking a different approach
You said the boat is now at your dock. Can a truck drive near to your dock? Just an idea but how about a septic system pump out service, or the companies that handle port o'lets. They might be able to come to you and run a hose to your boat. I don't know how much it would cost (definitely more than a shop vac) or even if it can be done, but thought I'd suggest it. That way someone else would have to worry about disposing of your "problem".
May 5, 2014
2
Macgregor 26X Dallas
how about getting a 25 gallon shop vac and put a fitting on the suck hose that will go into the deck pump out
I actually have a marina neighbor who tried that... about
there times, the shop vac and hose cleaning made him invest in something better
Jun 21, 2004
3,051
Beneteau 343 Slidell, LA
I have used a shop vac dedicated for this purpose. Just insert the hose end to the deck pump out fitting and vacuum. After all of the liquid is pumped, run fresh tap water thru the head and into the holding tank. Then vacuum the tank again. Its a nasty job--use rubber gloves; however, its cheap & it works.
Oct 17, 2011
2,809
Ericson 29 Southport..
It's best and cheap to just use a siphon. You know, just like you're getting gasoline out of an auto, only the taste is worse. Might wanna keep a stiff drink handy.
Feb 25, 2014
95
Catalina 30 Grand Lake. Wyandotte, Ok.
Hey Scott T. Priorities always. The Ag. run off is not a problem however the Goose poop is. One area of the lake is closed to swimming for coliform problems. I figured the cattle but turned out to be Geese.
And Chris I think I will pass on the siphon. Spit, spit.
I believe a septic clean out guy would be too expensive over time.
Since I have a sureflow pump I am going to use it and put a hose down the opening. Hope it gets enough suction to prime. It may be slow but will work till I find a better solution.
Jan 27, 2008
3,092
ODay 35 Beaufort, NC
Here's a solution that works just fine. Take the outlet hose off your macerator pump where it attaches to your thru hull for overboard discharge. Insert the hose into a 5 or 6 gallon plastic jerry jug. Turn on the macerator pump and observe when the jug gets close to full. Turn off pump, dip hose in a bucket of bleach water, cap jug and remove jug. Get another empty jug and repeat until tank is empty. Take jug home and pour carefully down the toilet. Same idea as a porta potti but the macerator grinds everything up into a nice liquid. Reattach hose to through hull and clamp. The outlet hose from a macerator pump is only about an inch so it fits into the spout of a jug just right. It helps to have a switch right near where you are working so you don't overflow the jug by mistake.
Beneteau 323 Annapolis MD
How about a tank either underground or above to pump from boat to large tank, then once in a while have the pump truck empty it?
May 4, 2005
4,062
if you go the shopvac route pull the filter before use... -I like the bucket in the middle concept. cheap/simple if it can lift that far.
a MSD porta pottie has a built in pump out. but its probably not going to have enough storage.
Good idea, Dave. Maybe take this one step further and connect the macerator output to the thru hell deck fitting and attach a hose from it to a tank on wheels on your deck.
If he even has a macerator, many lake boats do not. We sometimes keep forgetting that many of our fellow skippers have different systems than those of us on the coasts.
All sorts of options...
As far as chopping stuff up, Peggie has reminded us that #2 degrades very rapidly into liquid and that the appropriate paper also degrades, so there really isn't much hard stuff.
Oct 26, 2008
6,370
He's not worried about #2 ... like most of us on a lake, we simply don't go there. He's worried about the bi-product from an evening with 6 adults drinking beer. Honestly, the lengths we go to when common sense tells us that the solution is really very simple ... sheesh, think about the massive volume of waste from farm animals and the amount of nutrients from fertilizers and pesticides that are washed thru that watershed and then realize how little the impact from boatloads of beer drinkers can really be.
If he is that worried about the impropriety (or maybe enforcement is similar to Volusia County!) then I suggest that he cut a clean out hole in the top of the tank from where he can insert a hose and pump the contents on his lawn or into the septic field cleanout while he is resting at his dock at his lakeside home. The neighbors might not understand, tho.
