Holding tank cleaner
210
Hunter 34 Forked River, NJ
I just rebuilt my Raritan PH 2, and cleaned the hose from the head to the holding tank, my question is: is there a product that I can use to chemically desolve the buildup of sludge on the tank bottom? My tank is plastic, and original equiptment in a 1984, H34.
I am not sure it has a buildup, just think it may after cleaning the head and the hose!
We seldom use the tank for solids, and pump after a sail on each weekend. The entire system works properly, and we have no odor problems, I am just curious.
Dec 2, 1997
9,011
- - LIttle Rock
If it ain't broke...
The only cleaning your tank needs is a thorough clean water rinse 2-3x a year, especially in prepartion for any winter layup. If you absolutely insist on making work for yourself, put a gallon of liquiid detergent (Tide, Wisk) in it...fill it with water...go sailing and tack a lot...and THEN thoroughly flush it out with plenty of clean water.
Btw...it's not necessary to fill a tank to rinse it out. I've posted the instructiona enough times that you shouldn't have too much trouble finding 'em.
Dec 2, 2003
210
Thanks for the quick reply, and good advise, I feel better now, and plan to just water rinse a few times a year!
