Holding tank back-up?
A
Andy M.
After my 380 sits at the dock for a week or so, I get some, (very little) backup from my holding tank , into my toilet. This doesn't happen all the time........ I would say more like 1/2 the time. Could my holding tank vent be pluged up? Would appreciate any suggestions? Thanks Andy M. WWW.CALM C380 #380 San Pedro, Ca.
Tim
Joker Valve
I would guess it's some buildup on your joker valve allowing a little bit of seepage back into the toilet bowl. The joker valve is a rubber part that acts as sort of a check valve, that is supposed to allow one way movement of fluid (waste) out of the bowl. If a little bit of buildup occurs, it can perform most of its function, but will allow some seepage back. Reasonably easily replaced, maybe a little messy, but pumping your tank and then running a bunch of fresh water through the bowl into the tank should leave you with only a clean water mess when you disassemble the valve. Rebuild kits can be purchased for most all head models. They always include the joker valve. Good Luck! Tim Brogan April IV C350 #68 Seattle
