Forward Hatch Info
This is the info I have for the hatch over the V-berth:Bomar “low profile” model.Hatch No.: 1039-10AX, Hatch opening 19-1/4” x 19-1/4” [verify dimensions and model number]Note: Original replacement hatches for an 1988 boat are not available due to a fire at the factory that destroyed their tooling and engineering drawings.Installation: The radius of the new hatch is slightly greater than the old one so you'll have to fill in each of the corners with a bit of fiberglass.Bomar, Div. Of Pompanette, Inc.South West StreetPO Box WCharlestown, New Hampshire 03603Tel: 603-826-5791, Fax: 603-826-4125http://www.pompanette.com Oval ports in aft cabin and head:Portlight, EllipticalBomar Portlight No. 616 Elliptical. Portlight opening 5-1/8” x 15-1/4”, Hole cut-out 6” x 16”, smoke lens standard and optional stainless steel ring. Add ¼” (6mm) when using stainless steel ring in cutout.Replacement screen for 616: GS616 – 28. Cabin Ports BecksonBeckson Rain Drain™Replacement Part No. P/N P0410DBS-20, Port Replaced ~10 May 984 x 10 RAIN DRAIN PORTInside frame (hole size): 4-1/2" x 10-1/2"Outside frame: 6-1/4" x 12-3/4"Spigot: 2" Body windowP0410DBS-20 Black Smoked [coach roof]P0410DWS-20 White Smoked [aft cabin]BECKSON MARINE, INC.BRIDGEPORT, CT.http://www.beckson.comInstallation instructions: http://www.beckson.com/installport.htmlSealant: I'd second Neil's recommendation for Dow 995. Link to 995: http://www.dowcorning.com/applications/search/default.aspx?R=501EN
