Hitachi Data
According to the Yanmar Service Manual for the 12V/55A alternator:Nominal output is 12V/55A; however, the rated output is 53A at 5,000 RPM. According to the graph the output curent (for a NEW unit) is:0A @ 1000 RPM32A @ 2000 RPM47A @ 3000 RPM52A @ 4000 RPMAND, the output is spec'ed at ONLY 20ºC. At normal engine room operating temperatures the output will be significantly less (as Rick mentioned in reply #2). The Manual doesn't provide output information for other than 20ºC.My guess (just a guess), is it would be reasonable to assume somewhere around 35AMPs max at operating temperature and also assuming a NEW unit. As the alternator ages it is normal for the output to further decreases (due to diodes, armature, etc.).Voltage: the graph shows the voltage spiking up rapidly to 14.5@ ~1700 RPM. It doesn't show the voltage running up to this RPM but it appears it would be 0V at around 1000 RPM - per the graph. In reality, though, it's probably sooner than that. Unfortunately, it doesn't really matter what the lower voltage and RPMs are because until the voltage exceeds battery voltage nothing will charge anyhow.Wear due to age: If the alternator is original on the 34, the 8D plus the start battery probably have nearly worn out that alternator by now (is it original?). That may be why the question is being asked.It's a tractor alternator for low electrical consumption and not meant to run a (house)boat. Siting on the hook and running the engine to charge the batteries will carbon up the engine and cause premature wear. Diesels like to be worked, not babied. Don't have the crank pully dia and alternator pully dia handy but according to the table it would probably take a good fast idle to reach anywhere near 4000 RPM for alternator.Hope this data helps.
