HIN information
P
Phil
Hello O'Day Owners, What information is contained in the hull number for my O'Day 30? HIN: XDYS01G1M79K Does this number indicate which of the companies associated with O'Day production made this hull? Does it indicate the keel configuration? Does it indicate the number this hull occupied on the assembly schedule? Thanks, Phil
P
Phil
Sundance Sundance 20 Weekender Ninette, Manitoba, Canada
The telling HIN
XDY signifies that is was made by oday corp S01G1 is the serial number which can be deciphered further: S signifies the model name. (Mine was D for Daysailer) not sure what the S stands for in yours. 01G1 is likely an error that should be 0161 which is the sail number and also the hull number in this case. The M was common letter to all HIN which was followed by the year of manufacture (1979) and month. Jan=A, Feb=B etc. K=November. All manufacturers were required by law to imprint a HIN after November 1, 1972. Validate your HIN here: http://www.boatfax.com/index.php?option=com_content&task=view&id=17&Itemid=23&hin_cc=US&hin_no=XDYS01G1M79K
The telling HIN
P
Phil
Thanks
Thanks for the response to my request. I'll check the number for accuracy as you suggest. I checked the link you offered too. Best Wishes, Phil
P
Phil
Thanks
