Be wary of sailing theory (and some tips)
The theory of center of effort (CE) position relative to CLR as a cause of weather helm is OK....as long as the boat is near upright. That's not always the case in heavy air, so don't rely on it 100%.If the boat heels too far (which can happen under jib along in a strong gust) the forward component of the driving force from the sails moves outboard and to leeward of the hull centerline. Since water offers more drag to the hull than air offers to the sail, the sail moves faster than the hull in a gust and the boat tries to turn upwind. The answer is to reduce heel by reducing sail area.Since the wind speed is up, you're getting a lot more power per square foot of sail than usual. Since a typical displacement hull can only use so much power, any extra just causes more heel, i.e. the boat is overpowered.By reducing sail area, reefing gets rid of the excess power. As others mentioned earlier, sail power can also be reduced by tightening the outhaul and cunningham, and there are still several other ways besides. However, reefing is secure and places less stress on the sails and rig so they'll last longer.Since the boat isn't heeled as much, less rudder angle is needed to keep it on track, so there's less drag. Less heel also means less of the hull is in the water (less "wetted surface") so drag from the water is reduced. The shape of the hull underwater is also more symmetrical at lower heel (an unbalanced shape tends to turn the boat upwind). Again, less rudder angle is needed so there is less drag. Less drag means more speed.As several people already mentioned, you can depower the mainsail by easing the traveler or mainsheet in a gust. What's less widely known is that easing sail can increase power in a beneficial way. In a gust, the apparent wind increases speed but it also moves aft. Since we trim to apparent wind, the sail becomes overtrimmed in a gust. Easing slightly corrects the trim and since the boom angle is more open, more of the sail force is directed forward instead of sideways. When done right, the boat accelerates instead of heeling as much. There is a caveat...as the boatspeed increases, the apparent wind will move forward again so you have to trim back in. Watch small boat sailors in gusty air and you'll see what I mean. To do this, your mainsheet (and traveler if you have one0 must be easy to use and adjust under load. Power without control is useless.Sorry this got so long, but I learned these concepts painstakingly over the years and they have helped me to become a more confident and proficient sailor. I hope you'll find them helpful too. Happy sailing.PeterH23 "Raven"
