You really need to take tachometer readings at WOT to know what the engine is doing, and compare that to the published design engine speed. You can't pick a prop without knowing what the engine is doing.
Solas shows a 10x5 and 10x7 4-bladed high-thrust prop for that OB, but without knowing getting a baseline on how its performing now, you can't know where to go.
True this would be the most accurate way. I was just going from what the engine sounded like. If I can be at half throttle and have the boat around 5 knots and a bit better reverse I would be happy. I'll take a look around to see how available or how expensive a temp tach would be. I am a bit curious.
