Hi all, am searching for answers to gearbox problem, we are currently restoring our 1962 44' timber bridge deck cruiser and have suffered a seized Perkins engine (exhaust riser let go into manifold), am well underway with stripping engine onboard and rebuilding in situ (difficult but not impossible). The problem I have is : on removing all gearbox mounts and bolts (Paragon velvet drive box) have found the gearbox main shaft into the damper plate appears seized on spline and having a lot of trouble freeing box. Any ideas as to how this can be achieved? Have approx. 15mm opening at top of bell housing and am thinking of oxy torch thru gap and heating damper plate at spline to try and release gearbox shaft? Damper plate will obviously need replacing so not to concerned there. What does everyone think? Am running into constant seized/rusted obstacles all caused by previous owners lack of maintenance, had 3 weeks removing head from 1 stuck head stud so am getting used to these type of problems. Any help greatly appreciated.
Cheer's
Steve
Cheer's
Steve
