If you click on the Forums tab, and then select Social Groups, the list will come up. Just join the SSB and Ham group. To get to the Forum for this group, just click on the Forums tab and scroll down to the bottom of the list. You'll see us near the bottom, in the Social Groups Forum section. You have to join the social group first to post in the forum. You can always PM me if you need any help.
RichH, I like the GAM antenna and even have one for a backup. The reason it is a backup and not being used is there is one issue I have with the GAM. The GTO-15 feed line tends to wick moisture easily and fail. Not a problem for most antennas as you can simply replace the line in about half an hour or so. Unfortunately with the GAM, the only way to replace this line is to take the whole thing down and send it back to the manufacturer. If you're near shore, no problem. But if you are out and away from the dock for an extended trip, can be a big issue.
