I saw your photo of your holding tank installation in Roger Long's thread and I didn't want to hijack that one. Did you open up the hole in order to accommodate a larger tank? I assume your tank is under the v berth. I'm looking at doing the same thing but wonder about structural integrity of the v berth. I don't believe it would affect the hull but I'm not totally sure. My v berth has half round fiberglass stringers on the underside that would need to be cut in order to make room for a larger tank to fit in that space. The stringers could be re-glassed once the tank was mounted but that gets tough with the limited space and the fact that I'd be doing glasswork on an inverted surface.
Any thoughts?
Any thoughts?
