I can't figure out how to lower the dinette table into a double berth. I had assumed I would lift the table up off it's support posts... remove the posts and set the table back down on the wood lip around the front edge of the seats.... add the cushion I haven't figured out where to store yet and wala I'd have an extra berth ... but nooo I can't budge the table off the posts and the posts and table together don't lift out of the floor.
So what is the proper procedure? Thanks for your help.
Ok,
I know everything about this, so here goes..
First of all, the 2 posts come out of the floor bases & the table.
The problems are twofold:
The posts really get jammed in, and are hard to get out of either end if you haven't done so in awhile.
You need 2 people to gently & persistently rock the table upwards. I suggest getting a large rubber mallet and using it to give a few good well placed upward "taps" under the table.
I prefer this to applying too much pressure in lifting the table, as the posts are put in with rather short wood screws. You can pull them out if not careful.
Once the table is out, removed the posts from the floor mounts.
Then put a light layer of silicone grease on the posts where they meet the mounts. This will help them come apart easier next time.
There is a set of short posts that you really want to use if lowering the table . I don't feel that supporting it on the wood lip is adequate. Some 49s didn't come with these (like mine) , and I needed to order them from hunter
Next,,,
When you re-install the table, this can get tricky. If you have 2 people, then great. Just carefully drop it onto the posts.
If you are doing this by yourself, it's not so easy, as the posts can / will wobble
I drilled & tapped the bases & installed 1/4-20 thumb screws. This keeps the. Posts rigid as you move the table onto them from an angle.
Remember.. Put silicone grease on the posts, or they will be somewhat tough to remove
