I have Googled and searched the internet for some empirical information on how much is lost with an in-hull transducer. Logically I can accept that some is lost, but enough to make it worth drilling a through hole. Even side by side comparison test would be helpful.
I currently have my old transom mounted transducer bees waxed to the inside of the hull and it seems to be working fine, but compared to what. I don't want to epoxy it to the bottom until I have more information. I had it transom mounted on the Mac 25 but did experience some turbulence problems at high speeds or when the ob was on.
A separate question: I have an old through hull circa 1984 in the C27 that was attached to an old unit. I snipped the wire and left it in place. Could that transducer be used or is there a problem with soldering on a new wire. I thought I read once that there can be no breaks in the cable or you will get a false reading. Haven't seen that article or warning in the last 6 years. Is that unit generationally speaking outdated or are they still made the same?
Thanks Maine Sail for all that you do.
