John Richard
After a lot of thought and input about how I would attach a marine grade acrylic splash shield I came up with this design. It is made of half inch thick material with a one inch radius for each corner. The base is quarter inch and was glued on. Two quarter inch holes were drilled two and a half inches in from each end. The shield measures 9" x30". Beneath the corian counter resides a sheet of plywood which anchored the screws. One thing I had a little trouble with was that the corian is very hard. It bound up a drill bit and screw; both of which had to be snapped off and filed down. Fortunately, I was able to drill another hole adjacent which was then covered up by the screw's head. In the end, I think the project came out very well.John Richards/v Jack's Place
