So I have 2 small "holes" where stanchion leg screws have lifted the glass and gelcoat due to the stanchion being overstressed the wrong way. Want to fill these "holes" with MarineTex epoxy, but want to preserve the threaded "holes" inside the broken out areas of glass and gelcoat. What would one wrap around the screws that go into the plate in the deck that wouldn't stick to the MarineTex? I want to grind out the area, put the threaded stanchion support screws back into the deck, then fill in around them with epoxy and still be able to back the screws out and then replace them. Anyone following this so far? How about teflon tape or regular "blue painter's tape"? I'm wide open to suggestions.
