a few answers
No holes in the cockpit seats, I mounted a 3/4" plywood subface plate to the back of the sink/galley bulkhead with 2 5/16" bolts and built everything off of that.I used 2 triangle gussets to hold up the rear of the cabinet without taking up foot room in the berth. I made a template of the subface plate because it is the hardest piece to make, took forever to get it just right. After the cabinet body was installed, I face framed it in oak to make it pretty, and mounted the door & drawer face. Notice the cutout in the left door to clear the sink faucet. When the stove drawer is extended fully it sits on the old countertop with the dropleaf up to support it's weight. You can leave the dropleaf down and just stick something about 1/2" thick under it to support it. The propane bottle is a 1 lb. bottle that screws onto the end of a short hose and sits inside the cabinet space when the stove is pulled out. The stove is a Century 2 burner camp stove that I found at Walmart. The stove is mounted with wing nuts for removal to clean it. I used ball bearing type 24" drawer slides and mounted them on the bottom of a piece of 3/4" oak plywood. It works slick, but took alot of time to build and get everything to fit just right. Nothing is square, plumb, or straight in a sailboat. I'll take some more pictures and draw up some plans and post them in a day or so. If I can figure out how to shrink the template and keep it to scale I'll post it otherwise, anyone who wants a full size template of the subface plate send me a stamped, addressed envelope and I will send you a copy.Ross Terry1510 Forest Service 300 rd.Glenwood Springs CO 81601Mike B, Where is some good trailer sailing around Denver? I was thinking about McConaughy, ever been there?
