Hope someone can help me out here. I put my 1994 Hunter 29.5 in the water today, (yes I know I am late again as usual). Anyway, everything checked out fine until I noticed a very slight leak around the stuffing box area. I tightend down the stuffing box but still noticed water in that area. I cleaned up the water and placed some paper towel down to see where the leak was coming from and it appears to be coming from the point where rubber sleeve that attaches to the stern tube. I clamped it down the rubber sleve as tight as I could but it still leaks....not a lot but perhaps a drop every 15 minutes or so.
Also, for some context, I had the rubber sleeve replaced last spring but I think the alignment may have gotten out of wack in the process. As a result my stuffing box was over heating. Frustrated with the exercise, I took it to a marina who re-alligned my engine and advised me that the shaft was rubbing on the stuffing box, hence the heat. Once repaired, things worked well for the rest of the season. however, I am now wondering if that alignment problem last year may have worn or cracked somthing in the stern tube or log. If anyone has any comments or suggestions I would be grateful to hear from you. Otherwise it is back to the marina again and more $$$$$. Surprise surprise.
Thanks, Mike T.
Thanks, Mike T.
