First We need to hear the story !I've bent my mast and live in the middle of Indiana. What do I do?
Well, was using the gin pole to raise the mast on the HMS 23. Only the second time I've done it and I've not figured out how they intended the foresail to attach and was trying something different from the first time. Got the lines tangled, couldn't get the mast all the way up but I could pin the side stays to hold it, which I did. Got the lines untangled and realized I was going to have to lower the mast because I needed to change how I was attaching the foresail and then without raising the gin pole back up, I pulled one of the side stay pins, had a Willey Coyote moment as I realized what I had done and was pulled over backwards as I tried to hold the mast up with the sidestay. Bent where it it the side of the boat.First We need to hear the story !
Lake Monroe? Where else can you sail in the middle of Indiana?
I live in NW Indiana and sail on Lake Michigan.
Greg
Yes, it left a dent on the mastI'd have to see photos - is the mast dented? Bent in a sharp bend where it hit the boat?
dj
Interesting. Our 70' mast was made in two sections and sleeved together. Skipping Stone is over 40, with her original mast, and I'm guessing it will probably be around longer than I.As a former sailboat dealer , I cannot recommend any sleeved mast repair unless the sleeve is designed specifically to that mast. I have seen too much as a dealer and safety comes first over saving a buck. Period!
I agree, but a good metal working shop "should?" be able to do the job properly, don't you think?@capta
You have a sleeve specifically for your mast to sleeve it together. Selden masts are designed to be sleeved together with the sleeves specifically designed for each spar.
However. A sleeve not specifically designed for that extrusion means a lot of issues and failures
