I was going to move my 31 today from Gandy Bridge to its new homeport on Treasure Island. I was about one hour out into the bay when Engine trouble hit. I was going about 5kts @ 2700 RPM. BTW, my Boat is in need of a bottom job and there is plenty of growth on the hull, but I cleaned the prop and shaft a little while ago. Sudddeny, I heard a sound like pffffffffffff and the enginge went down to idle and some black smoke came out the exhaust. I turned the engine of waited and started again.After 2 min. same thing. I decided to turn around, waited a little and went back at 1700 rpm making 2kts. No problems at that speed. 1-1/2 hour later nearly back at the harbour I tested it again it and ran 2500 rpm with no problem for about 5 minutes. I can't get the engine above 3000 PRM what I believe is because of the bottom. I checked the airfilter, where I found only a metal mesh but no filter, I found oil in the filter cover.I was under the impression that the exhaust looked a bit blueish, but not much at all. My problem is that my old marina closed (conco project) and kicked me out, I am in a hurry to vacate the boat and now this. Any information is welcome, might this be an easy fix, big job ?Thanks siggi
