HELP with stuffing box
maxxx
Oct 15, 2009
60
oday 28 Ft. Loudon lake
Help!!! I need advice on how to tighten the stuffing box (packing ???) on my Oday 28 with the 11 hp Universal. I just paid a shop 100.00 to do something I should know how to do!!! All advice appreciated.........max
RAD
Jun 3, 2004
2,330
Catalina 30 Bay Shore, N.Y.
Well you need two water pump type pliers and if not familiar with how to do it then do a search and you'll find an excellent post from one of our contributers on stuffing boxes also you might need to replace the packing but first try and tighten but don't over do it cause you'll score the shaft
Apr 14, 2009
37
Aux Middle River, MD
be careful! once my friend tightened his stuffing box too tight and eventually affected the shaft's ability to rotate so best to gently tighten it and test it :)
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
First loosen the lock nut (aft-most nut). (I like to use packing nut wrenches -- Home Depot for about $15). Put a wrench on the lock nut and the compression nut (fore-most nut). Then turn the compression nut, one "flat" at a time. After you turn the nut, check the drip rate (depends on what type of packing material is in the gland, but on most you should get no leak withe engine off). Then try to turn the shaft by hand to get a feel for how much friction is on it. You should be able to turn it by hand (I turn it at the transmission coupler); if you cannot, you have over-tightened. Then, with a wrench on both nuts, turn the lock-nut to lock it against the compression nut. Now, run the engine in gear (tighten up dock lines if in a slip -- don't try this at a mooring!) at about 1500 rpm and check the drip rate again. If it drips too much --- more than a few drops per minute, you may have to the procedure all over again -- but no more than one "flat" on the compression nut at a time. The idea is to adjust it just enough to keep the gland no more than warm to the touch.
1,077
Several Catalinas C25/C320 USA
Next time the marina does something like that for you...watch them, take good notes, then you can do it next time.
maxxx
Oct 15, 2009
60
Thanks !! I'll do a search but have found a good starting place with this forum in the past. Unfortunatly, my boat is 4 hours away and I thought it needed the attention sooner rather than the next time I could get days off. By the way, what type pliers do I ask for at the Depot??? Thanks again to all!! max
5,802
I have tried various wrenches and pliers for adjusting the stuffing box. Finally settled on two aluminum pipe wrenches, eight inch I think. They are lightweight and don't slip off the nuts. As was pointed out be sure to secure the front nut which is actually the "box". You don't want the hose to twist on the stern tube. While you are there check those hose clamps or replace.
P.S. there should be four stainless clamps, not two.
