Fond memories...
I purchased a new Snark in 1969. In those days, the basic Snark model was a plain hunk of molded styrofoam, with no plastic or fiberglass coating. Just raw high-density styrofoam. Shortly after making the purchase, we moved from the State of Washington to New Jersy. We cartopped the Snark from one end of the country to the other. When it was a couple years old, it snapped into two pieces, laterally at the spot where the mast support hole is located. I cemented the two pieces together, using a contact cement designed for styrofoam. Then I covered the entire hull, inside and out, with fiberglass cloth and resin, in the manner we used to cover wooden boats. I set the boat on saw horses and did the job in the garage. I finished the effort by painting the fiberglass-coated hull with a two-part epoxy, bright red. If I have to say so myself, it was a beautiful job. It added a lot of stiffness to the boat, lessened the need to be super careful in avoiding dents and gouges in the raw styrofoam, improved sailing performance by giving the hull a much smoother surface, and greatly improved the appearance of the little boat. We sailed it for nearly four more years, then sold it to a neighbor when we moved back to the West. Perhaps a similar restoration would work on your boat: sand the hull thoroughly, then recover it with fiberglass cloth and resin, and give it a good coating of epoxy paint. I have fond memories of my old Snark. It was my first boat, and it taught me a lot about sailing techniques.Good luck,Dale
