After enduring the winter and early spring, I fired up the Yanmar 2GM last weekend. The motor ran fine, but there was a new vibration I've never had before. Went below and the attached video was what I found. Would love the perspective of all the wise heads on this site.
Is this a cutless bearing/shaft alignment issue? (it's the original bearing and it's 32 years old)
Or potentially a motor mount? (all original)
Or does the packing nut on the shaft simply need to be tightened?
Is this amount of water normal? I don't normally see this much...the packing area was cool to the touch.
