jim hayes
i have 3 battery boxes mounted aft of the engine and above the transmissionthere are two of these side by side forward and a third aftthe starboard forward battery box is filled with a liquid within an inch of the top of the batteryany guesses on where the liquid came from or how to diagnose it???i do not think it is acid because no acid smell and the battery itself is fulli am trying in the tight confines to drain the liquid out so it will not rise over the top of the batterymy pressure water is tripping a breaker on the dc panel after les than 5 secondsthe starboard side of the panel next to the engine seems wetis th pressure pump located to the right of the ac part of the panel behind the port saloon cushions????would this battery box be under the pedestal guard??? the previous owner replaced the guard with another yet ran the wires out of the existing holesthis may be the leak or it may be related to the pressure water problemthanks for your wisdom
