Help with mainsheet halyard
K
ken
So my halyard for the main is at the top of the mast. Short of dropping the mast or going aloft in a bosun chair..... anybody got any wisdom on the sybject??
Oct 3, 2006
1,033
Hunter 29.5 Toms River
Do you have another halyard?
If you do, use it to hoist a length of pvc pipe taller than your mast up, with a hook on the end. Maneuver it around, grab the main halyad, and retrieve it. I take no credit for this - just remember seeing it on the board
dmc
Jan 29, 2007
67
Hunter Cheribini Lk. St. Clair MI
Go to the local hardware
get 3 or 4 pieces of plastic pipe. Make a hook of wire (#9 ceiling wire should be good)and tape it to one end. Have a friend, one that won't laugh too much, sit in the cockpit with field glasses. It helps to paint the hook a bright color, so you can see it. The pipe is less flexible if it has a thicker wall. It's not easy, but it is possible. Good luck.
caguy
Sep 22, 2006
4,004
If it will make you feel any better,
met a guy and his wife who on their maiden voyage with their brand new Catalina 25 lost their halyard inside the mast when he tried to tighten the sail a wee bit more. Novelman and I retrieved his jib halyard by duct taping a straightened clothes hanger to the main halyard. I cut the hooked end with a sharp bevel. Worked like a charm without the PVC, although I can see where the PVC could help. It took about 15 min most of which was walking back to the truck to get the coat hangar. Frank
W
Warren Milberg
Every one who sails
has lost, or will one day lose, a halyard up the mast. My favorite remedy is money. Hire a kid from the rigging shop to go up and get it. Last time this happened to me it cost $15. Probably up to $20 now.... but worth it.
Aug 4, 2006
47
Catalina 309 Cutter Marina, Chesapeake Bay
Been thar...done that!.,,,,,,,,,,,,,,,,,,,,,,,,
In fact, I had both halyards run up the mast accidentally during the last sailing season, at different times of course. Not wanting the hassles of dropping the mast, I duct taped two extended whisker poles together and secured a coathanger hook to the end of one with duct tape. Then it was just a matter of balance while reaching the snap schackle with the hook. Simple and it worked. Good luck!
