Help with "Leben ist gut"
Yuxian
Oct 15, 2012
4
Hunter 37 Cherubini 143 Ashtabula
I recently got back onto the Great Lakes with the 1980 hull 143, 37 Cherubini. Fortunately, over the years, this boat has had many upgrades/changes. And while I'm not a novice to sailing, I have far too many questions to go this alone without the help of some former and current owners of 37Cs. I'm hoping that even some of you might have owned and sailed "Leben".
She is presently rigged as a sloop, but I have much of the gear to revert back to a cutter. I have never sailed a cutter. My first question is: How many of you would consider such a change and why?
She has an arch/davits frame (nothing attached yet). But, I know nothing of the windage and problems large solar panels might cause when sailing? I've trailed a dinghy, but wonder if anyone would ever carry one on davits during a passage?
Any help or comments will be greatly appreciated. Thanks,
Dan
Dan, how you plan to use your boat should be the basis of whether you go cutter or not. If day sailing, most likely not worth the effort, both to do it or to sail it. If, OTOH, you plan long distance Great Lake sails, then it may be worthwhile.
Solar panels WILL create windage issues. How they are installed and what size they are will determine the impact. Cruiser Forum has many discussions about this issue. There is one very trustworthy skipper who notes that he uses his generator in lieu of solar because he races (56 foot boat, too). Others have removed generators after installing solar. You mention "passages." I don't know your plans, but if you're staying on the Great Lakes, you really aren't dealing with the kind of passages the skippers on CF regularly make. The 56 foot boat owner has been sailing from UK to the Baltic and back every year for decades. A two day or two overnight trip is not really a passage - compared to the Baltic trips or UK to the Med, or even from Maine to Florida, Seattle to Mexico. Good luck with your new boat.
May 31, 2007
784
Hunter 37 cutter Blind River
I've had three Cherubinis, my 37 for about 13 years, all in Lake Huron. I am a big fan of the cutter. The staysail often improves the boat's balance and the rig is extremely versatile for adapting to changing wind and sea conditions. I had a very poor set of davits on the 37 but never used them for the dinghy or solar. However, they made a great handhold and stabiliser when using the dinghy or kayak. I am not a big fan of adding extra weight way aft to these skinny arsed boats that already squat pretty low when under power.
Yuxian
Oct 15, 2012
4
Thank you, both, for your input on this subject. At our age it's difficult to answer how long we might spend underway, though, I think most of time we would only be looking at a day or two with actual distances under 100nm. I'll do some searching on the solar panel discussions cause I'm thinking on Lake Erie they might really create some serious problems in wind and waves. And yes, this boat's Atlantic arch is located far aft, and the more I think of it, the less I like the idea of sailing with things attached to it. Still, I'm sure for living aboard in quiet waters it probably would be fine. Again, I am wide open to any discussion on this and I thank you guys for commenting.
Yuxian
Oct 15, 2012
4
One more question: Can any 1980 Hunter 37C owner tell me dimensions for a dodger for this boat? Or, this something early 37C owners avoided for some reason?
Aug 17, 2013
1,316
Pearson P30 202 Ottawa
A dodgers dimension depends mainly on what you want, you should contact a canvas maker to see what would suit you best.
Do you want a standard simple dodger or a California dodger?
It really depends on your needs and desires
A California dodger is usually bigger but has the advantage of removable windows, turns it in a sort of Bimini, greater visibility when docking and driving and gives you a lot more air, not as stuffy.
If you already have a frame then just need to get a pattern made before the building of the skin.
If you don’t have a frame already, the sky is the limit for you.
Yuxian
Oct 15, 2012
4
Thank you Fred for the thoughts. I definitely would want a dodger with removable windows. I used to sail at night in the past and I definitely would want maximum visibility. In my 1980 Hunter the traveler is right outside the companionway, so, whatever dodger I get has to not extend very far.
