Help with fixed port replacement
Hunter 34 Herrington South, MD
I'm about to replace my fixed ports again on my '84 H34 and have read the great threads on Owner Mods, but would like to replace the plastic frames with new material. Does anyone have a source for making new frames for the fixed windows? I've tried the internet but no luck.
Feb 21, 2013
4,638
Hunter 46 Point Richmond, CA
Which port window below do you want to replace? If you have not already might check with the SBO store for Hunter 34 ports and windows in the link below. Also link provided on a Sail Magazine article entitled "Replacing Fixed Portlights".
Nov 6, 2006
10,149
I share your pain, Mike. I searched for the material to make them, but never found the extrusion I needed. The only thing I have thought of would be to have them done on a 3D printer, then painted to keep the UV from eating them in a couple of years.
Artey1
Jul 18, 2019
165
Hunter 34 Oklahoma
I'm hoping for a project in the future to revive my benchtop cnc and mill these interior frames out of aluminum. Until then I'll be trying to reuse my plastic ones like you gents. They really shouldn't be that hard to model in Fusion, just need to get my machine going again!
Artey1
Jul 18, 2019
165
Hunter 34 Oklahoma
Would be easy to do two sets?????
Haha, probably not that hard, but again, my machine is down right now and I have a bigger issue with my chainplates to solve before I even think about getting it going again. This is something I hope tackle in the next year, but not any time soon, sorry Mike! Was just hoping to pass ideas around. Especially like Kloudie mentioned in 3D printing them. Both would require a model be done first. If you were handy enough with welding aluminum you could even do some out of small angle aluminum, a miter saw, and a sander I bet. Those would be harder to duplicate sets of however
Actually I have a MIG welder that can do aluminum and I also just purchased the torch fired aluminum rods. Maybe I will try to weld up a set from extruded aluminum, using my radial arm saw and one of my 6 sanders.I'll look for some z shaped extruded aluminum like some of the articles mention. But considering I've been restoring the boat for over a year, this portion of the restoration might coincide with your chain plate work.
Likes: Artey1
I may have the real answer! I spoke with Sailboat Owners store and they gave me the name of Mark Plastics in California. Mark Plastics(951) 735-7705369 E Harrison St # GCorona, CA 92879 or markplastics.com
Apparently Mark Plastics made the plastic replacements for the earlier aluminum frames. that have maybe one screw outside at the forward point and many screws inside. They now make them with tempered glass for about $1300 delivered for all four fixed ports.
Likes: Artey1
Mar 20, 2011
623
Hunter 31_83-87 New Orleans
+1 on Mark Plastics. They had full replacement fixed ports for my H31. Easy replacement and looks great.
Nov 6, 2006
10,149
Shannon, How do they work with the slight curve in the cabin rise? problems installing? Lots of glass work to get close to the new dimensions ?
Jan 5, 2018
187
Hunter H34 0828 New Orleans
No glasswork. Just measure 3x (template) and cut once and trim to fit with deemed. Use blue tape to mark the outer boundaries of your cut. Jig saw with a blade for cutting fiberglass (not wood). Tape the portlight box to the inside of the window; template and cut from the outside. Do not cut from the inside! U need the perfect cut on the outside.
the windows fit and seal up fine. 6x 1’s; 3x 2’s; 2x 4’s; and 1x 4L and 4R.
Nov 6, 2006
10,149
K.. so the 4L&R 's are longer than the existing hole, allowing the radius cut instead of the point of the originals?
Jan 5, 2018
187
On my ‘86 H34, the original 4x fixed windows were all rectangular and equal in size. The outside had an overlapping plexi which gave the outside a trapezoid look.
Mar 31, 2020
6
Hunter 34 San Rafeal
I installed one fixed plexiglass window to replace the two leaking aluminum one. Was easy and looks great.
Likes: Don Crowther
