OK all you expert gearheads, here's a scenario for you:
A Yanmar 3GM30F has a pronounced knock at idle. The knock is coming from number one cylinder. Flipping the decompression lever on number one while running makes the knock go away, opening numbers two and three has no effect.
The engine starts instantly and shows no smoke while running, so compression appears excellent and there are no apparent fuel problems.
The knock goes away as RPMs increase, and the engine hums (ticks, actually) like a well oiled sewing machine at cruise RPM with no evidence of knocking.
A rapid increase in throttle from idle does not aggravate the situation, nor does a rapid decrease in throttle from cruise RPM cause the knock to occur.
What do you think? I may be just wishfully thinking, but based on what I believe I know about engines, if the knock was coming from a main, crank, or wrist pin bearing or from piston slap, there should be some knocking at cruise RPM, or during a rapid increase or decrease in throttle setting. The fact that the only time knock is evident is at idle leads me to believe it's a late injector. Opinions? Other things to try to diagnose?
