Help What's it called
5,836
Hunter 36 Punta Gorda
Hi can't find it that stainless cleaner that you brush it on and rinse it off.
Has any body used it and how do they like it,does it really work good and where do I find it.
Nick
Feb 27, 2004
134
Hunter 410 N. Weymouth, MA
Nick
Winchinox is the product I've used. re-passivates the stainless. awesome product. haven't needed to touch my stainless in over 4 years. bought it at both defender and west.
Bryce
Dec 19, 2006
5,836
Some thing else
Thanks but the product I am interested is called something else and I think it's a liquid that you brush on and leave on a short time and than rinse with water hose,I think ??????
Feb 6, 1998
11,772
Spotless Stainless
Nick
Spotless Stainless (LINK)
= Direct mail order only
The stuff works quite well though is a tad slow and on some older stuff and may require two applications.
Some things I have learned about it.
Do not use in direct sun
Do use it on a warm humid evening so evaporation is kept down
It won't work well in cooler temps
Work on the shaded side of the boat if working during sun up hours
Don't stand their watching it
Here are the ACTUAL photos of Spotless Stainless working. Thanks for inducing me into getting around to uploading them..;)
Temp 68F, humidity 63%, set time 1:20 minutes, only because I got side tracked. I can't accurately comment on how long it actually took to get that clean. This was a 25 year old Wichard snap shackle that I have had on a number of halyards. The surface is pitted from time and exposure, and the Spotless Stainless won't fix pitting, but it did and does remove the rust very well even if a little slow. In higher temps and humidity it does seem to work faster. Below 70 degrees it seems to begin to slow down.
It is what it is:
Before:
During:
After Rinsing:
Not bad for doing nothing but brushing it on, letting it sit and rinsing it.
Oh and YES I do find it a tad expensive but don't doubt the price will come down when volume eventually goes up.
Yesterday the boat was on the mooring and after a sail I busted out the SS and a chip brush. Worked up near the bow. While waiting I got some paperwork done then went back and rinsed it off. Overall really, really easy. The ability to clean stainless while I am doing work for my "real job" is really quite nice..
For rinsing it I used a bucket of water and a wet microfiber rag. I did not feel like going into the dock to rinse down or to get out out my on-board hose. Rinsed off fine..
I also tested a spot where I waxed over some rust purposely. It does not work very well unless the stainless is unprotected and may take considerably more time or perhaps not work at all depending upon how thick the wax coating is.
These pics were all taken yesterday 6/23/10..
Before:
During:
After:
Temps were 78F with about 84% RH and it worked in about 30 minutes today. It was however direct sun so I had to keep it wet. I discovered that you can cover it with a dampened and wrung out microfiber rag and it keeps it wet longer.
Keep it wet and use in warm temps and the stuff really works and leaves a very nice shiny surface.
For experimentation's sake I tried it on a seacock. I also used a Mr. Clean Magic Eraser with the Spotless Stainless. This took a long time, a lot longer then the stainless, but the results were great when it finally had enough time to do its work. Getting through the verdigris took a while but this is right next to my nav station where I was working so it was easy to keep an eye on the progress..
I don't advise using the product in this manner, not its intended use, but I did do it.
Dec 2, 1999
15,184
Everyone with a boat should have a few of these Miracle cloths aboard. The really work and they are cheap.
http://miraclecloth.com/
They help remove salt and rust from SS when other products would not touch it. You can buy them on ebay for a couple of bucks each.
LuzSD
Feb 21, 2009
1,009
Catalina 30 San Diego/ Dana Point, Ca.
wow, these are great pictures, I want this stuff! Thanks for taking the time to document it for us. I used some paste stuff when we first bought our boat and got the stainless to look pretty great, but I was left with very black hands, lots of mess and it did not end up looking as good as your pictures show. Thanks alot!
2,288
C30 Event Horizon Port Aransas
Bryce I am impressed with your testamonial for winchinox. The first week we got our boat, we cleaned off all the SS rails. We went back two weeks later and it had all rusted again. Very dissapointing. The only good part is that is doesn't get much worse after the first two weeks or so.
when I paint my deck I will try that product out on the SS.
Related question: In the marine hardware stores, all they have is 304 SS bolts and hardware. Is it worth it to find 316 hardware or just live with the light rust on the 304? I would gladly pay twice the price for 316 but no one seems to have it. I used 304 on the bow roller I made and the plastic table and accessory holder in the cockpit and as predicted it is somewhat rusted. Whe I get down to mounting things through the deck I really need to do it with 316, does anyone know a good source?
Apr 1, 2009
62
None right now Cruiser Don't have on yet
Hermit,
you might try FASTENAL, I use them for alot of my hardware, they have a local wharehouse and their prices are decent. They have a pretty good website, but you might have to do some digging for 316.
