Help sizing & sourcing a main for 1985 H33 (77_83)
220
Hunter 33_77-83 Yucatan, Mexico
If anyone at all can help, I have just bought a 1985 Hunter 33 (77_83), which is lacking a main. I am looking for a main, but could use any assistance as to measurements (standard rig). Pictures can be made available (pullenbob@yahoo.com) for anyone willing to assist, if necessary. Much appreciated. Bob
Jun 3, 2004
309
Prindle 18, beach catamaran Chicago (North Edgebrook), IL
H-33 mainsail
Bob - I have a Hunter 33 from 1980. Last year I replaced the original main which I still have but don't use with a full baton 8 0z. version. Both sails have a high aspect ratio. I also have sail measurements but I am not sure if you have the same boat. Is it a Cherubini? Not sure if the production lasted into 1985. Let me know if it is the same boat. Can email me through owners directory. Henry
Jun 2, 2004
87
Hunter 33_77-83 Montevallo Al
Katrina sails?
I think I remember Jim Logan having sails from a H33 that was destroyed in Katrina. You may be able to contact him through the owner directory. I am sure that there are other H33 sails out there that were taken from boats before the storm that were subsequently destroyed. I have an extra mainsail for a H33. As far as the year, check the number on the transom. They weren't make in 1985.
Paul F
Jun 3, 2004
827
Hunter 1980 - 33 Bradenton
specs
The sail specs given on this site are I=42'6" J=14' P=37'1" E=10'9" for the 77-83 33'. This is a store I have heard good things about, but have not purchased from. They have many used sails. http://www.mastheadsailinggear.com/ They are in St. Petersburg. You likely have good lofts in, or near your area.
Aug 20, 2006
220
thanks and please add at will...
thanks and please do keep them coming...I will be leaving the boat tomorrow and soon will have more time to follow up on the excellent leads! unfortunately this area does not have any sail lofts, but I do have some time as I don't plan on being back aboard before 12/1 thanks again Bob
Dec 1, 1999
2,391
Hunter 28.5 Chesapeake Bay
Go to Bacons
online and you'll get the theoretical sail plan -- and any used sails they may have that may fit. But I recommend that you take a long piece of line and measure the maximum luff and foot of your particular boat. If you buy a new main from a local sailmaker, he'll measure your boat for you, taking into consideration a number of factors that may need consideration (bimini clearance, backstay/topping list clearance, etc). You;ll also be able to discuss your particular needs with him, like cloth weight and type, batten types, reefing needs, etc. Unless you are really budget stressed, having a new main made for your boat would be my strong preference.
