My boat is an hour from the house. After some of the monstrous rains this summer (3, 4, even 5 inches at a time) I had to trek to the boat and empty the bilge (beyond the normal little leaks, I think the water is coming from top of the mast).
So I'm looking for some sort of automatic bilge pump that will eliminate the need for a trip to and from the boat. I currently have a small Rule manual pump. I'm debating whether to get a float switch and add that to the pump (I assume the wiring now would go directly to the float switch and then wire the float switch to the pump?)...or get a totally automatic pump that doesn't mess with a float switch.
Rule seems to make a couple of smaller automatic pumps that should fit in the rather small bilge on the boat. The reviews on them are OK.
Any advice regarding these two choices would be most helpful. I'm leaning on replacing the current pump with an automatic model with no float switch (seems to me that a float switch is just one more thing to go wrong)....would love to get some lessons learned from the wise heads on this forum. Thanks in advance.
