The 3GMF Yanmar on my Hunter 35 is fitted with Racor Spin-On filter to remove water and solids in the fuel and comes complete with a glass inspection bowl and base mounted bleed screw. No integral pump. Seems to work fine but routine checks are almost impossible. I can not get my head anywhere near the bowl to inspect contents and, because the unit is mounted above the fuel tank, nothing comes out when I open the bleed screw. I would really like to be able to place a glass under the bleed screw and run a little fuel into it to see if there is any sign of water. The only solution that I can think of is to change the position of the priming bulb, which I have installed in the fuel line downstream of the Racor to avoid having to use the lever on the fuel pump to bleed air on the low pressure side of the fuel system. If I move the bulb upstream of the Racor, I presumably could open the bleed screw in the Racor base and pump a little fuel out with the bulb.Any other solutions out there?
