Jef
The main hatch (not the forward one) is leaking. The leak is comming from the piece of wood that acts as a stopper so you can't pull it all the way out. I tighted it as much as possible, but it still leaks. I'm assuming there was a gasket that went bad. Since I'm not even sure if there is a gasket there, I don't want to screw it off and I don't have a replacement. I could probably just use some type of sealer but I can't really access it since the top hatch (the white half) is blocking it. To get it off, I would have to remove the wood and then I couldn't seal it. Any suggestions?
