Owned a 1976 CM26 for 16 years (1985 to 2000)
Check out:http://www.scbiz.net/jcox/http://www.clipper-sailor.net/http://bbs.trailersailor.com/forums/clipper/index.cgiOur CM had a tiller attached to a transom-mounted rudder, no engine well (cut-out on starboard transom for outboard), no portlights in the pop top, two-axle trailer.The picture does look like the typical clipper bow but the ports don't look right.Hull number started with "CM".Good luck. If it is a CM, it is a very strong boat, designed by W.E.B.Crealock. Try to catch him some time when he gives a presentation at a Pacific Seacraft dealer. He can tell you a lot about your boat (if it is a CM).Post a photo of the cockpit. If there is a small rectangular well (~9"x12") to port of the companionway, then it is CM.
