Has anyone installed a autopilot on this model Hunter 33?
Decided to install a EV-100 in my 33. I have the wheel portion installed but the wiring seems to be somewhat of a problem. The wiring in the instrument pod runs down the port binnacle guard leg. It is full with a lot of wiring. It has a pull string installed. The wiring runs down the leg and then into what appears to be some sort of chase and exits in the aft port side near the fuel tank. Here is the problem mixed in the bundle is a pull string which goes down the leg and seems to exit in the aft then runs to an opening in the stern rail under the aft light. The pull string seems to be two different strings, pulling on either end will not move the other end, it is possible that the pull string from the top on the binnacle exits somewhere else? To add to the fun hunter plug the aft end of the chase with caulk, which I will have to remove at some point. Also in the binnacle are some unused wire runs, I will have to trace those to see what the are, I may be able to pull them back to get more room. I have to run a Seatalkng cable and the power cable for the wheel pilot in chase.
Looking for some advice.
Thanks
Thanks
