Help me understand my DC charging/depletion
Oct 29, 2016
1,929
Hunter 41 DS Port Huron
To close this out, bad parallel charge solenoid. It isn’t a perfect connection, hence my elimination of it early on, doesn’t beep a continuity tester, it’s a higher resistance connection but enough to leak current from start to house.
will replace with an ACR if it’s plug and play and all the existing cables and terminations work, otherwise with a new solenoid at least temporarily
Thanks for the follow-up, even better that you found the issue
Glad you found it.
An ACR should work with the same wiring. You just won’t need the extra positive wire to power it closed.
