Help me find a prop shaft zinc for a 2004 Hunter 41 ?
Dec 25, 2000
6,071
Hi Jim, as far as I can find out the H41 prop shaft diameter is 1-1/4". Our P42 is the same. Prop shaft zincs of that diameter can be found in most any marine chandlery; very common and inexpensive product.
Jan 11, 2017
68
Hunter 37c Kingston
You need a new repair guy!!!
I try not to get into negative commenting but I can't imagine not being able to go into a chandlery anywhere in North America and not buying 1 1/4 shaft or conical zincs. Are you sure your "guy" is a knowledgeable guy?
