Hi all,
My '79 Hunter 33 has been sitting idle at dock for two years (including Hurricane Sandy). I finally had it hauled and the bottom cleaned up reasonably well with just a power washing, all things considered. The majority of the bottom paint applied two years ago was pretty much intact. There are however, lots of small barnacles and growth that should be removed prior to painting. The yard requires dustless sanding. I'm not trying to remove all the old paint. I did a bottom coat job a few years back. I also switched bottom paints with the last painting. For years I was using the Interlux Micron paints, but changed over to the Aquagard line primarily for cost.
Now, since I don't really want to strip all the paint, but primarily the growths, what would be the best route to follow?
I found an adapter skirt on EBay that fits over a grinder head and connects to a Shop Vac, but I also saw several dustless sanders used for drywall. I was wondering if anyone has used these and if they work.
Thanks
Thanks
