It is a drain so to speak on my new sail drive from Beta. Technodrive Seaprop. From Italy. To change the ATF while floating, I have to remove an M10 plug inside the boat and replace it with a hose barb with ATF pouring out all over the place. Then, tape over the vent and then pressurize through the dipstick hole at less than 5 psi. So, I would like to replace the plug with a petcock that has a hose barb to keep things clean. The process works well. I pressurize into the dipstick hole with an air nozzle that has a rubber tip and pressurized from a bicycle tire pump and a pressure gauge. I put a petcock in from a cylinder from my old Volvo MD 17C and I can put a one gallon jug up to it. But, it's at a shallow angle and it would overflow. Should work better with a hose between a jug and a proper petcock...That's my story and I'm sticking to it!
