Ric Shultz
I posed these questions before with only one response. Do I call Rudy?Question: 1After 1000 hours of work I am almost ready to launch. I have a Oday 25 CB. The boat is launched each time from my trailer. With the rudder on, ther is about 6" of ground clearance. Can I launch with the rudder on or do I have to put it on after it is in the water? It looks like a chore to do afloat as it must be turned sideways to fit the pins in.Question 2On my old boat, I split the back stay with a yoke over the rudder to center the mast pull. It helped the boat sail up wind equally both directions. I'm thinking of doing that on the 25, but if it makes no real difference, why bother. Also, a trangle of cable over the rudder may make it more difficult to install the rudder afloat, if thats required from question 1 above. Also, it may complicate my ability to add a bimini latter? So, is it worth splitting the backstay to get a dead center pull on the mast, considering these other factors?Ric
