This is a fuel gauge off of my fuel tank. It is not mechanical in nature and I suspect it works via resistance or capacitance. The missing tap is round so orientation is correct when installing on the tank.
Before I remove the broken lens, I was hoping that someone would recognize this gauge and can tell me when I might fine one. If I can not find a replacement, my options are to remove the entire sender and install a new sender. But this may be a problem as I think senders are not standard diameters or screw hole location standard either. Which means either replacing the tank or modifying the tank.
Any help would be great. I am sure if I remove the lens I will be able to see the manufacture, but then that makes the gauge vulnerable to the elements. On top of that, the one tab is missing due to damage with taking the gauge off the tank (my bad).
Thanks
Thanks
