Congratulations on the upgrade.
Congratulations on the upgrade.I did the same thing 2 years ago. And find that the 27 is less trouble to get under way than the 22 after all no crawling under the dinette to lock down the keel. She is a bit heavier so keep that in mind when you come back to your moorage and slow down a bit sooner, as long as she has forward momentum she will steer. Backing up is an issue that has been discussed here. You will be surprised how far she will move with one good push from the dock. A few times out and you will see what I mean. I have an inboard diesel so it’s really a matter of getting the beer on board and in the fridge, tiller cover off, mainsail cover off, shore power disconnected, start engine, cast off dock lines and go.Of course this is assuming you have all of the required safety equipment for a 27’ boat.Now if you’re talking for a weekend or more, well that’s another matter…Not in any order: Fill diesel tank, fill water tanks, pump holding tank, check fuel for heater and stove, store food stuffs, store clothes, cameras etc, put dingy in the water, crab pots in dingy, double check that you didn’t leave anything you need in the truck or sitting on the dock, then do above.
