Help finding Remote oil change fixture
mytime
Aug 26, 2014
86
Hunter 2007 Marlow Hunter 33 Middle River, MD
We are a new owner of a 1994 Catalina 30 with a Universal 25xpac. I noticed that the boat is equipped with a remote oil change fitting on the oil pan drain plug which allows the oil to be changed from a remote tube leading from the bottom of the pan.
The rubber hose on this connection appears to be pressed on...This pressed on fitting is leaking and I would like to replace it with a new one however I can not find part # or where to purchase. Does anyone know of where I can get a new one? ...Thank you
Aug 8, 2009
52
Catalina 30 MkII Forked River, NJ
Are you sure its the hose that's leaking and not the oil pan? I just had to replace a corroded oil pan on my 94 C30. The parts were very expensive and were only available from Westerbeke. Feel the bottom of the pan or use a mirror to see if it's bubbled. I had oil in the bilge for a year and kept hoping it was the hose, maybe you'll be luckier.
mytime
Aug 26, 2014
86
Yes ...I placed a mirror under pan and I can see the drip trail starting where the pressed fitting attaches to the pan plug...This is going to be a "messy" repair and I want to be ready with appropriate parts...It appears to be as old as the boat ...20 years
Apr 11, 2010
992
Hunter 38 Whitehall MI
When we had our Catalina 34 our yard service department was always able to get Universal engine parts. You might try a local yard.
Otherwise Catalina Direct might be an option.
Or I did a quick internet search using the search terms Universal Marine Diesel and got lots of hits. So I'm sure you could find something there although it may be a Catalina custom addition in which case the Catalina sources might be better.
hewebb
Oct 8, 2011
329
Catalina Catalina 25 Joe Pool Lake
My boat came with one of those. One day I was motoring and the engine quit. Turns out the hose cracked open and the oil drained. Big mess. I had to have the engine rebuilt.
Universal engines are Kubota tractor engines. Basic engine parts are easy to get.
Apr 27, 2014
22
Catalina 30mklll Hudson, FL
I just pulled the engine out of my 1995 C30, MKIII to do some work on it. I noticed the oil drain hose had been rubbing againt the stringer and outside jacket and wire mesh was worn away exposing about 3 inches of the inner rubber hose! I could easily have had a disaster like Hewebb did!
I found a replacement hose with fittings on line for about $140. I also found an oil drain valve which looks like it would be much better and a lot less expensive $23.95. http://www.oildrainvalve.net/ez-oil-drain-valve-2/. I have ordered one and a 90 deg. adapter to connect a hose. I like the idea that I can shut it off at the pan instead of having oil in a drain hose.
Has anyone installed one of these?
BTY way, my engine is M-25XPA and the thread for the oil pan drain is 12mm x 1.25.
mytime
Aug 26, 2014
86
Thanks Capt Dean...It seems like a simple solution. I already ordered the other part however I may rethink my current set up based on hewebb's bad expierience
mytime
Aug 26, 2014
86
CaptnDean... I think I will try that valve (thanks for supplying thread size)...I will post pics after install...I think it is a very practical install..... I like the idea you can shut the flow off...this will correct any issue of a hose failure that hewebb had.....
Apr 27, 2014
22
mytime, I didn't see any dimensions for the physical size of the valve, so I hope that there is enough space below the drain pan for the valve and the L-fitting. I ordered it anyway and its on the way. I'll let you know if there is a space issue after I receive it.
Mar 20, 2012
3,983
there should NEVER be a fitting in place of the drain plug that cant be shut off to prevent the oil from draining/dripping out in the event of a hose leak.... there are a few different brands/models of closable drain valves that can be used with a hose attached.
a much cleaner and quicker oil changing option is to use an oil evacuator to pull the oil out thru the dipstick tube.... with a good evacuator it takes about 5 minutes to change the oil if its already warm.
Likes: 19thol
Feb 6, 1998
11,760
Every Universal & Westerbeke & Beta has had one for eons. This thread is the first time I've read of a hose failure on a Universal or Westerbeke oil sump hose.. These engines have oil pressure alarms and very often oil pressure gauges too. The only way for the engine oil to drain out and seize an engine is if these systems were simply not maintained, like the hose.
At each oil chage this hose should be visually inspected, like many other items, simple stuff. What about those customers with remote oil filters. I work on many boats where the filters have been remotely located to make changing less messy and to give more oil capacity and even increase filtration surface area. We can't really valve off a remote oil filter...;) We also have transmission oil coolers and and engine oil coolers all of which require external hoses which can not be valved off with the engine running.
I suppose we could take that concept a bit further though and say that every hose on an engine should require a shut off valve? Antifreeze? Fuel? Oil bypass hoses, remote filter hoses, oil cooler hoses?
These drain hoses are short and have a spot right on the engine to keep it secure. If the engine is properly installed, and the installer made sure nothing can chafe that hose, then they can easily exceed 30+ years of service just as thousands and thousands already have. You could not pay me to go Yanmar style and suck out my oil through the dip stick, I do enough of those servicing other peoples boats and rarely does the oil get "clean" nor does it repeatably result in a thorough oil change unless you do it twice..........;)
The Westerbeke drain fitting is very robust compared to the valves shown in this thread and it is also specifically designed to be very low profile........
jrowan
Mar 5, 2011
1,294
ps. Don't know if you've ever actually drained / sucked the oil up through the dipstick hole with a standard suction pump. It is a royal, slow PITA. Takes 5 minutes? Ha, try about an hour of continuous pumping as it comes out in literal drips and drabs. I wish the oil pan drain plug was actually accessible on these engines, cause it would be a heck of a lot easier to drain the oil out.
mytime
Aug 26, 2014
86
I agree with jrowan...I have only changed mine once since I owned it but it seemed to take an hour+ on a 60 degree motor... We are now at 14 degrees and I will try this weekend. I picked up a magnetic oil pan heater which I will leave on overnight. I hope it will go much smoother.... the heater is 200 watts and claims an output of 150+ degrees
jrowan
Mar 5, 2011
1,294
Never thought of using an oil pan heater before to heat up the oil, but why not just start & run the engine up to operating temperature which will quickly warm the oil & thin it down so its not so thick & hard to pump out? It would certainly be a lot cheaper. Unless you are on the hard & your engine is raw water cooled like my old 5411. Bu then you can still feed the intake suction cooling hose into a bucket of water for cooling the engine while in dry dock. My 2 cents.
Mar 20, 2012
3,983
absolutely have sucked oil up thru the dipstick hole... i use a mityvac fluid evacuator.
on some of the equipment I service it is designed that way, because that is the ONLY way it can be done. there is no hose attached to the pan because its prone to failure, causing engine damage, as stated by the manufacture...
boats arent the only objects that have been built around the engine, rather than the engine being installed after the object was built:D
many oil services I do dont allow for the possibility of an oil drip... its considered careless and shoddy work in some enviroments... intel is about the nit-pickiest place you've ever seen. so we suck the oil out and pump it in...
when the oil is hot, it will suck like water (almost).... a gallon of oil takes about 70-90seconds to be sucked thru the dipstick tube, at the engine operating temp of 180degrees.
and i would suppose it would depend on the design of the oil pan more than anything else, as to whether enough oil can be removed to "clean the oil" when changing it... and if the suck tube reaches to the bottom of the pan.
some pans have a sump for the drain plug, and some have a sump for sucking from the dipstick tube...most have neither one.
truthfully, i dont know if an oilpan used on a marine engine is designed differently than any other, but there are many random and thoughtlessly designed oil pans in existence.
there will always be a bit of old oil left in the engine oil pump and galleries that will remain, and even a pan designed with a drain plug sump will continue to drip oil for a couple of hours if it was left it open that long.... but normally we drop the oil, wait a 3-4 minutes and then replace the plug... while it is still dripping/accumulating in the pan....
i also dont know the shape of the pan on my westerbeke 30, but ive seen the insides of oil pans on all types of engines, and many of them either have a ridge/boss built up around the drain plug for strength, or the plug is mounted on the side of the pan..... both which leaves a fair amount of oil in it when draining from the plug....
I dont believe that 10% of the old oil remaining in the pan is any worse than going over the oil change schedule 20-30 hours. if the filter is doing its job and if the engine is being serviced timely, the oil in the pan wont be in very bad condition, and the dilution ratio will be low enough that you can be assured of good service life from the oil, even if you do run over a bit on the scheduled hours til the next service...
some people change the oil every year no matter the amount of hours they put on it, and others opt for changing it at a certain number of hours, no matter how much time has gone by.
there are a lot of variables and a lot of leeway when deciding how and when to change the oil, and what method is best.
as for the drain hose that is attached to the oil plug hole for draining... I know there can be many exterior pressure lines on an engine that could fail at any time during its operation, but never have I seen any applications where there is an external line attached to the pan below oil level, that is intentionally left without a shutoff at the pan...
but because some of these engines are installed in such a way that the pan cannot be touched, let alone reaching the oil plug, this could be one of those things that is a bit specific to the boat industry for the convenience of changing the oil if one chooses to drain it rather than suck it out... and thats OK if thats the only way it can be done.
I have seen a large number of engines that were installed on flat skid-plate units that have no "below" to drain the oil into, and they have a long hose connected to the pan in place of the drain plug.... this is intended to be ran to the side of the pan and over the edge so the oil can drain into a bucket... or sucked out. some of these hoses even have to run uphill a couple of inches to get to the edge, leaving some of the old oil in the engine, and this is an OEM arrangement. the hoses frequently fail near the connection and drip due to the vibration of the engine..... but there is always a shutoff valve in the oil pan drain hole that the hose connects to....
as normal as it is in a boat to have the hose connected to the drain hole without a stopper valve, its still a bad idea... but I will concede that with proper maintenance and inspections, the risks can be very low... but then, if you could get to the drain on the oil pan to replace the old hose with a new one, you could probably operate a quarter turn valve there also:)
Feb 8, 2014
1,300
Columbia 36 Muskegon
Never, ever, buy parts from Westerbeake for a Universal engine. That is a Kubota tractor engine, and the only "marine" parts on it are the raw water pump and exhaust manifold. You can get parts at the local Kubota shop for 1/10th to 1/4 the price. The raw water pump (Oberdorfer) is available from Moyer Marine and others for about 1/2 the price. If you need an exhaust manifold, you're SOL but could probably have one custom made cheaper than what Westerbeake would charge. The only way to get these guys to quit charging criminal prices is for EVERYONE to just stop buying from them.
Tirade over. I would remove the drain fitting and take it to the Kubota shop and see if they have one that can have a valve attached to it. (I wouldn't run it without a valve. Failure is rare, but it does happen and even with an oil pressure alarm, it can wreck the engine before you can get to the kill switch.) The Kubota counter guy will want to know what tractor the engine is in, he doesn't know what a Universal is. I don't have the cross reference handy, but it's available on several threads on this site. The drain plug is probably the same on all of Kubota's smaller engines and there is probably one with an OEM valve and hose setup.
If they don't have one, I'll bet an industrial supply house will have a metric setup that will work.
mytime
Aug 26, 2014
86
Well i finally got around to changing the oil pan drain nut.as CaptnDean recommended (Thank You!) I had difficulty unscrewing the existing plug due to tight space...could not get a socket on it. I tried to measure it for a open end wrench and found the fitting was only hand tight. (possibly vibrated loose?). I placed a $30 oil pan heater on 30 hours before draining oil at a exterior temp of 25 degrees and I was able to suck out oil with a hand oil extractor in 50 min.
Interesting note: When I pulled drain plug off there was less then 20 drops of old oil left in pan so clean up was minimal. I attached new fitting (recommend a snubby adjustable)and 5 minutes later I was back in business.
http://i151.photobucket.com/albums/s152/Matt19020/KIMG0183_zpse0662cbf.jpg
http://i151.photobucket.com/albums/s152/Matt19020/KIMG0181_zpsea76f3ee.jpg
