Get a Multimeter
Hi --Troubleshooting wiring problems in most cases requires a multimeter.These days you can get one fairly cheaply at radio shack.A short in the wiring that would cause this kind of issue usually means that somewhere, the negative (or ground) side of the circuit got connected directly (not through an appliance or 'load') to the positive side of the circuit. In that case, the current draw will be so great that it will burn up your wiring.To troubleshoot, first look for hot-spots. Places where it seems there was more heat than others. Likely you will find wires virtually welded together, or to a ground source, like the faceplate of the breaker panel. Something like this would likely be the source of the problem.Another way is to disconnect the batteries at the post, then put your meter (in the ohms position) across the positive and negative battery terminals. If the meter reads 0, thats a dead short. Move up the line to the next place it connects (breaker panel, batt switch, whatever), isolate the 2 circuit runs (the one back to the batt and the one forward of the batt switch or whatever) and measure again. A dead short (0 on the meter) on the battery side means its someting back towards the batteries. A dead short forward, and you have to go forward and isolate the circuit, probly at the breaker panel. At this point, it should be fairly easy to isolate the individual circuits that run the appliances in your boat, but turning the circuit breakers 'off'. Of course you have to be careful that it isnt your battery or a particular CB that is shorted, although Ive never seen that happen.Its not as complicated as this might sound. Just remember that current flows from neg to pos, and needs to flow through a load (like an appliance or light). If it has a path directly from neg to pos, thats a short circuit, and it /will/ take that path.Your mission is to find that path.Hope this helps.Duane
