Help!!! companionway crack
rob
I am thinking of buying an Oday 28 and there is a crack between the inner and outer liner at the companionway opening along the bottom. Is this a common thing for these boats and should I be worried about it? (goes 8 to 10 inches and is about 1/4 inch wide)
Jun 2, 2004
1,438
Oday 25 pittsburgh
This started to happen with my first O'Day 25.
It was just a crack when I bought the boat. It never grew, I never fixed it. If you want to do something, This is simply the connection of the deck and cabin connection. You could probably grind it out far enough to make a sound connection. I would not try to simple cover the crack repair. It would return. r.w.landau
Paul Mieszczenski
I have one on mine
Rob, My O'28 has the same crack and it has not been a problem for the 6 years we've had the boat. It was sugguested here on this forum some time ago that the crack is caused when the boat is on the hard with the ladder connected to the brackets. The O'28 is one of the best sailing boats I have ever been on and that is a lot of them. Last weekend I trimed the sails for a close reach, set the wheel lock and didn't touch a thing for the next 3.5 miles at 5.5knts. Only reason I had to make a change then is that we were about to run into the mangroves. We have about 2,000 miles on this boat now and have no complaints whatsoever. She is perfect for a couple to cruise in. PM
Dennis
Yes it's common
I have an O'Day 25 that I've owned for 12 years. Great boat, but it is time to move up. I want an O'Day 28 and have looked at several over the last 6 months. Every one had the crack at the companyway. I've come to accept this as a characteristic of the 28. Another characteristic is spider cracks around the winches mounted on the doghouse, if and only if, the lines have been run aft to the cocpit. Boats that do not have the lines run aft do not tend to have the cracks on the doghouse.
