Help choosing an adhesive
Sailm8
Feb 21, 2008
1,751
Hunter 29.5 Punta Gorda
About 6 feet of my rub rail was damaged and needs to be glued back on to the plastic U-channel over the hull/deck joint. From what I can see the stuff that was used by Hunter was black in color and sticks like 5200. The shattered U-channel is stuck in the rubber rub rail and will need to be cut or scraped out. Anyone who has replaced rub rail, what did you use as glue?
Mar 26, 2011
3,961
Corsair F-24 MK I Deale, MD
