Tom
Hey Guys need your help. My 90 Hunter Vision's 3GM30F has a problem. After running for awhile at 2800 RPM's my engine starts sputtering. The RPM's drop off and I get a big blast of black smoke. I can then manage only to go at about 2300 RPM's. If I try to go above 2300 she will sputter and put out a blast of black smoke again.I changed the two fuel filters, the Racor 110 and the Yanmar fuel filter on the engine and it did not correct the problem. FYI, the racor was dirty but the yanmar was clean.I have heard, change the fuel filters, change the gas, clean the fuel injectors, change the impeller and the thermostat.What do you think???Thanks for your help!Daddy's Dream
