Hello H37.5 Owners!
G
Gary Wyngarden
I have a very serious interest in one of two Hunter 37.5's on the market up here and would appreciate your help. I have read all 35 reviews on the web site and am clued in to an overall very positive reaction as well as some nagging problems with Hood furlers, tanks, and a possible need for a third reef point on the main. But I have a few specific questions. The intended use of the boat would be for singlehanded and crewed daysailing, some short cruises in the area of the San Juan and Gulf Islands, plus some longer term cruising (two-to-four month) to some more adventurous places like the West Coast of Vancouver Island and up the Inside Passage to Alaska. The questions: 1. How hard is the 37.5 to singlehand? With lines led to the cockpits, the dutchman flaking system, and an autopilot, I'm not seeing any problems here other than the usual excitement of docking in a cross wind. Any thoughts? 2. Recognizing all of you have one or the other, what is your opinon of the deep fin keel versus the shorter winged keel for this boat in terms of sailing characteristics? One of the boats has the deep keel and the other has the short keel. 3. I can't find the engine hour (Hobbes) meter on either of these boats. Where did they hide it? 4. What's been your experience with the 37.5 in really rough weather and seas? Any other advice or input will be appreciated. Gary Wyngarden S/V Shibumi H335
Mat
We are enjoying ours ;D
We have had our 1992 37.5 for 2 years. 1. I have never tried to single hand the boat but it should not be any problem if you have done it on other larger boats. 2. Ours has the short bulb keel. I have had no problem pointing and it allows me to get into some shallower water. 3. There is not an engine hours meter installed. 4. I have been in winds to 30 kts and rolling seas to 6-8 ft. I reef the main early (about 15 kts) and the jib around 18 kts. I have found it to sail well on jib alone. This winter we are having a winless installed and upgrading our radar. Enjoy the boat. Mat S/V Just Ducky
Brian Leney
9 seasons and still going
We've had our 1995 H37.5 for 9 seasons and love it, which is why we still have it. In response to your specific questions: 1. I single-hand often when underway, since my wife is usually below entertaining my infant/toddler daughter. Must have auto-pilot to single-hand successfully, especially to raise and douse sail, but I can sail easily myself with standard layout on this boat. To help with docking, you must install some mid-ship cleats, which did not come standard on this boat. Attach them to the genoa car track or toe-rail (bolt-on for about $80.) The boat has a lot of windage due to its voluminous below-decks design, and that hurts docking in a cross-wind. Also, some of the later builds of this boat, had the genoa winches installed on the aft winch pads in the cockpit, next to the helm, like ours, while earlier models had those winches installed on the forward pads, next to the "crew." Obviously, the aft location would be eaiser for single-handing (and you could relocate those winches if they aren't that way already). I personally would prefer not to SAIL single-handed--it takes a lot of work to do alone, especially when in close proximity to the shore and when going up-wind. There are sailboat designs that would be easier to single-hand than this Hunter, e.g. those with cat rigs. I've already forewarned my wife that if I don't get my crew back soon, we will be trading the boat for a Nordic Tug! 2. Deep fin vs. winged-keel has to be your call for the areas you intend to sail. Absolutely we need the shoal-draft for the type of sailing we do: coastal, up creeks and rivers, shallow harbors. 3. There was no standard hour-meter installed. We installed one, easily, when we first got the boat, in the starboard lazerette next to the battery switch. $40. 4. Our boat has occasionally been in "rough weather and seas" but only so far as the Chesapeake can throw it. Me personally: there are things on the boat that I would strengthen before crossing oceans and confronting major storms--primarily hatch covers and the hold-downs that secure them. But that is for my peace of mind--others may feel differently. On the other hand, the walk-thru transom lets a boarding wave leave quickly! Other advice: as you've probably already learned: --Engine and stuffing box access is superb --Plan on replacing the aluminum holding tank soon, if it's still there. I have plenty of advice on how to, since I did it last year. It's easy and not expensive. --The boat is a wonderful value, great sailer, and great for a couple, or couple with small children Good luck with your selection. Brian
Jul 1, 1998
3,062
Hoisting Main
Gary - thought of something that one might not consider when considering a larger boat - that is, hoisting the main. These Hunter models have fairly large mains and as one moves up in boat size the mainsail is larger and made with heavier fabric. On our H-35 with the OEM UK sails that came with the boat it wasn't too much of a problem to hoist the main all the way up, provided everything was working for me and the slugs/track were clean, and winch it tight for the last foot or two. However, when I put on new sails I went with the next heavier fabric so they wouldn't blow-out as easy and it's measureably harder to get that main up. Well, the H-37.5 has a much bigger main than the 35, or the 33.5 for that matter, both in size and cloth weight, so hoisting that hummer is going to be a workout and most likely a lot more winching than you've been accustomed to. The first year of the 40.5 had only a manual main halyard winch but in subsequent years they had electric main halyard winches to deal with the hoisting the main problem. If the main is a lot of work to hoist then the skipper will probably be thinking twice before setting sail. In my case I have to go through Agate Passage before reaching the main channel so with my old sail I'd drop it and motor through and hoist it again on the other side. With my new sail I just motor through and leave the sail up wanting to avoid haveing to re-hoist it. There have been other times when I've had the sail up and down several times in a few hours as the wind builds only to die again. With a heavier sail you're going to just motor and say to heck with it. Anyway, that's just one more thing to think about - something you won't notice until you go sailing for the first time. On the other hand maybe the young bucks in this forum would take this as an opportunity for some good exercise.
Don Rice
In Praise of Coastal Cruisers
I had some friends that looked at over a 100 boats including a 336 several times and couldn't make a decision. I sent them a copy of your article from the archives and they bought the 336 out of Annacotes within the week - and now your moving on! At any rate, I have a 35.5 and unlike them I bought the 1st boat I looked at. (the bride said yes and I wasn't missing the opportunity) My concerns regarding open ocean cruising are mainly with the stiffness or lack of. It has a fairly high ballast/disp ratio of 37% but with the wing keel it still seems a bit tender. I think they would be better suited with a deeper keel to lower the vertical centre of gravity. The 2nd issue is that they have CNG versus propane on these models and although it is far safer it does not produce the same heat and it is harder to come by. (need minimum 2 tanks) As for the issue with the main - on the 35.5 I can raise it just past 1/2 way mark manually and winch it beyond and I am not superman but I am in reasonable shape. I don't view it as an issue as if I raise it in the morning it's usuall up for the day. I will furl the genoa when motor sailing but the main stays up until I completely give up on the wind.
Don Rice
Engine Size
One last thought is that I beleive they have the same Yanmar 3GM as the 35.5 and your 336. With 16,400 displacement it might be a little under powered for some of our passes.
G
Gary Wyngarden
37.5 Responses
Thanks for your responses. I share your concern about hoisting the main. One of the boats I'm looking at has Battcars on the main which is probably indicative of the problem and at least one solution. With respect to the Coastal Cruiser issue, I still believe everything I said in that article. My primary point in that article was that "intended use is the number one criteria in boat selection." Our intended use includes plans this summer to spend two months on the boat on the West Coast of Vancouver Island in Barkley and Clayoquot Sounds. Within two years we expect to make the trip up the Inside Passage to Alaska. Can we make those trips in our 335. My answer is yes, but. We've spent three weeks on cruises on our 335 on three different occasions and have had great times. But space can get small and I had the feeling on our trip back from Barkley Sound two years ago that we were pushing Shibumi's limits. While I know the 375 is blue water capable (with modifications in my opinion) I still view it as a beefed up coastal cruiser. We don't intend to cross oceans with it. What it would give us is more comfortable living space for longer cruises and for having friends and family join us, more tank capacity for added range in the sparsely populated areas in which we cruise, and a stronger boat for the stretches across open water up the coast. It also has a sail area/displacement ratio that makes it lively in light winds, a big enough cockpit, is still small enough to singlehand, and is at a price point relative to the 335 that makes it a reasonable stretch for us in comparison to many of the other boats we've looked at. Again I see the 375 as a beefed up coastal cruiser that matches our intended use at a good price point. Hope this clarifies things. Gary Wyngarden S/V Shibumi H335
Phil Herring
Alien
Mar 25, 1997
4,924
- - Bainbridge Island
keel
Although I've never sailed a 37.5 I did own a 35.5... and if you have a choice go for the fin keel. The boat will point and perform better and I don't think the waters around here are shallow enough to worry about a shoal keel. The 1-1/2' of keel you add here won't matter here, but it sure does in the Bahamas, which is probably where the concept for shoal draft came from. I had forgotten about the engine HP... my 35.5 always felt a little underpowered to me. Not enough to be scary, just inconvenient sometimes. Maybe a more efficient prop would help.
Marc Honey
Reasonable upgrade
Have followed your writings and escapades over the years and this seems like a much more reasonable upgrade than the $200,000 plus pilot house cruiser you were kicking around not to long ago! I'm actually looking at 33.5, 35.5, and 37.5's myself to complete my move to the Fla. panhandle. Shoal keel for me, DEEP keel for you I would think. I plan on going with a furling boom so I can keep full battens and high roach in the main. Best of luck Gary with your decision.
Mark Burrows
1992
Did Hunter re-power all of the ##.5 boats in 1992? I know the 33.5 went from 18 to 25 HP that year. Markdb
Dec 5, 2003
204
Hunter 420 Punta Gorda, FL
Legend 37
We owned a 1987 Legend, the same boat, for 11 years. It was a great boat. Mainsail handling - keep the mainsail track clean and lubed and you can easily pull the main to within 1 to 2 feet and then winch the rest. Reefs - I had 2 reef points and never used the 2nd reef at all. We sailed in winds up to 45 knots and 10 foot seas and the boat handled well. Got knocked down once in a sudden squall with 69 knot 90 degree windshift. We had just turned into the 15 knot wind to lower the main and got hit with a sudden gust. Put the mast into the water but came right back up. Single handling - I had an Autohelm 4000 which worked fine for single handling. We cruised several times for over 2 months in the Bahamas, and the tankage was adequate. We carried 3 spare CNG tanks and used over 3 in two months. We had the wing keel and it handled fine. The fin would be better if you have the depth. Engine - ours had a 3HM35F which is 30 hp continuous. Plenty of power. The newer ones have a 3jh engine with more power. Hour meter is an owner add-on. Tanks - ours had plastic tanks from the factory and never needed attention. Recommended Boat. Good luck, Bill Bell
Don
My 37.5 comments (1993 model) ...
I echo most of what others have said, especially Brian of Annapolis. I basically live aboard my boat solo. I moved up from a H31 and love it, although I sometimes long for my 31 (fewer systems, less $$ invested, etc.) (One note: the extra space and head room in a 40.5 would be very, very nice. If you haven't been on a 40.5, I encourage you to do so beforehand just to see what you're missing. The difference is something more than just 3 footitis.) A few more facts I can add: 1. I usually single hand my '93 37.5 and am in the middle of taking the boat to Florida solo. With the autopilot (WP-30 on mine) it's easy to set and go. I can fix dinner while the boat sails itself so long as I'm not in thin water. Everything is easy to reach and it's great to sail. 2. The PO of my boat did extensive cruising of the east coast and south (Puerto Rico, and father I believe) and lived aboard for a number of years. From what I understand, they really put the boat to the test and it handled everything very well. They returned to land life after almost 10 years with the boat. I've been in a few serious storms but all Ches Bay related. I can say, however, that the boat will definitely take more than I can. 3. They added a 3rd reef point and the mid-ship cleats that Brian mentioned. Both are invaluable. 4. Raising the main will make a man outta you if you're not already one (or a real woman depending on the circumastances!) It's tough, I won't lie. The batt cars might make it better. I keep exploring options (e.g., strong track, elec winch, etc.) as it's not easy and I'm not getting any younger. 5. I added a windlass because solo you almost have to have it. I put in a Sprint flush mount, it's ok but not state of the art. For serious sailing/cruising I think you will need to install a serious windlass and, because of the deck arrangement, I'm not sure how you'd do it. Something to consider. 6. My boat came to me with a fully enclosed cockpit and I will definitely have on any boat in the future. Invaluable. Rather than the standard dodger/bimini setup, this one has a full bimini from companionway to the stern. I love it. 7. As for the keel, I can't speak to that. I have the wing and it point's incredibly well. Crosswinds do tend to push her sideways and if the deep keel minimizes that and draft isn't a concern, go for it. But IMHO the wing keel sails incredibly well. 8. Serious prop walk in reverse with the 2 blade prop. You basically have no starboard reverse. 9. Alum tanks are an issue although I haven't had any problems. I'm keeping my fingers crossed. It's a great boat and seems to be well regarded in review, surveys, etc. As I said, the PO did lots of customizing to my boat which has proven very nice. If you get one, I'll be glad to give you details on anything I can.
G
Gary Wyngarden
Done Deal
Well, I took the plunge and signed a contract to buy a 1992 37.5 yesterday. The boat is in great shape though it needs to be more fully equipped for cruising. BTW with the Battcar system I was able to fully raise the main by hand without the use of a winch (I'm 57)! We're really excited. Now how do I say good bye to Shibumi? Gary Wyngarden
Terry
Congrats Gary on your new boat. The 37.5...
is one of Hunter's best boats IMHO. Hope to see you lurking around the islands this season. What's her name? I'll keep an eye out for Shibumi, too. Terry
G
Gary Wyngarden
Thanks, Terry
We're pretty excited about it. Her name is currently Kiwi Flyer but we'll be changing that. No decision yet as to what the new name will be. Saying good bye to Shibumi will be tough as she's a really good boat. Gary Wyngarden
Rick Sylvester
Congrats Gary
Although we're proud owners of a 40 we very nearly bought a 37.5 and I still think it's one of the best looking boats Hunter ever did. As for a name, I think you should give the board a little background info and make it into a contest. Surely, with all the nutjobs that contribute here you'll get stuck with, uh, I mean we'll come up with a beaut. How about a weekend charter for the winner? Um, I'm in Florida, could ya throw in the plane ticket?
Jack
Congratulations, you bought a good boat
Gary, I think you bought a good boat. A strong coastal cruiser with some bluewater capacity when needed. I bought a 1991 37.5 three year ago, having owned three previous boats, all racer/cruisers with deep fin keels. My 37.5 with the shoal/wing keel does not seem to sacrifice much performance upwind in comparison to my previous boats. Nor does it seem to be appreciably more tender. I love the roominess and the interior layout, and I am so far happy to put up with the CNG for safety sake. I intstalled a full encloser in the cockpit: Large bimni, dodger, connecting (removable) awning to join the two, and zip on side panels. What a difference in bad weather. I in effect single handle the boat a lot. My original sheet winches were on the forward pads. I added two more on the aftmost pads near the helm; it makes like easier. The autohelm 4000 does a nice job. I also installed midship cleats by sawing out a a two foot portion of the vertical part of the toerail and bolting a cleat through the horizontal part the toerail and the hulldeck joint, with a good oak backing plate underneath. As to raising the main. It's great you have battcars. I keep my track lubricated (with McLube) and have no difficulty raising a newly made and heavy main to within three feet of the top and winch it from there. The engine is not as powerful as the more recent models of boats in this size, but it's bigger than what they put on these boats in the 70s and 80s. I have no real problems. AS to reefing, as you know the internal one-line reefing only allows for two reef points, as far as I can tell. Here is what I did when I ordered a new sail (Doyle with Stackpack) to replace the tired main that was passed on to me by the previous owner. Calculate the highest point in the sail that the second reef can go. This is a function of the length of the boom, because of the internal reaafing systems inside the boom. This "high" second reef will be higher than the "standard" one, but not quite as high as a standard third reef. You can also have the first reef place a little higher than is normally the case, somewhere between where a first and second reef would normally be. This arrangement seems to work for me, although sacrificing the traditional placements of the first and second reef may be troublesome, if you plan to race the boat regularly. Do yourself a big favor; get rid of the continuous line Hood roller furling system. It is a bloody nuisance. Hood, realizing their mistake sells a conversion kit to replace the existing drum with a standard single line. Its a bit pricy, but much cheeper than getting whole new system. The converted system works very well with the drum still below deck level in the anchor well. I installed a low-profile vertically-oriented manual windlass up front on the deck. Hunter has a drawing of the recommended placement for a 37.5. They faxed it to me the very same day I talked to them. Again, I am glad I did it, and have had no problems. My low-profile model is a combined rope-chain one, both rope and chain bulled in the same drum teeth. For this you will need to do a tapered rope to chain splice for smooth operation--again an easy task. That's all I have time for now. Sorry for all the gratuitous advice. Congrats and enjoy the 37.5 Jack
