Helix Mooring Anchor
41
Oday 272le chatham ma
Has anyone used a Helix Type mooring anchor to secure their boat. I have a 1500 lb Compac Suncat that I keep just off the beach. I don't want to use a mushroom because it is very shallow and I don't want to damage the bottom of the boat. I could use some feedback from anyone that uses this system - where to buy it and the best one to use. I keep the boat on a lake and it is fairly well protected.
Nov 17, 2011
1
I keep both my boats moored offshore using a 3 anchor mooring system. I use 3 danforths on my mcgregor it sets in 1 to 3 ft of water depending on the tide. They have held up to a 58 knot blow. Once dug in they are not a factor in hurting the bottom of your boat. Just make sure the swivil is off the bottom so the rodes don't twist
Jan 26, 2009
100
HUNTER 340 Raritan Yacht Club
gjaffess,
The mooring provider at my yacht club installs them. Swears by them.
Send me an e-mail and I will give you his tele number. He's a nice guy and can give you all the info you need.
wmmulvey@aol.com
Bill
Bob S
Sep 27, 2007
1,815
Beneteau 393 New Bedford, MA
gjaffess,
I posted this to the wrong post created by you. It belonged here.
I remembered reading a BoatUS Hurricane Prep Guide
http://www.boatus.com/hurricanes/assets/pdf/hurr_prep_guide.pdf
The first question, then, is: Will your mooring hold? As a result of numerous moorings being dragged during recent hurricanes and northeasters, a search has been underway for a more secure mooring anchor. A study by the BoatU.S. Foundation, Cruising World
magazine, and Massachusetts Institute of Technology (MIT) found that a 500-lb. mushroom buried in mud could be pulled out with 1,200 lbs. of pull (supplied by a 900-hp tug); an 8,000-lb. deadweight (concrete) anchor could be pulled out with 4,000 lbs. of pull. A helix morring, however, could not be pulled out by the tug and the strain gauge recorded 12,000 lbs. of pull—its maximum—before a shackle was burst apart by the strain. Scope in each case was slightly less than 3:1. (In another helix test, a strain gauge had
registered 20,800 lbs. before the hawser snapped.)
After reading that I would prefer a helix mooring over a mushroom.
PaulK
Dec 1, 2009
1,541
Sabre 402 Southport, CT
Our harbor uses helix anchors for about half the moorings - perhaps 150 out of 300 boats.
They work so well that for Hurricane Irene, people were worried that in the tidal surge boats would be held under water by their mooring pennants if they weren't lengthened. This shouldn't be as much of an issue on a lake.
